Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
342 Fragen Alle anzeigen
Can I install a 2TB SSHD on my iMac?
I just tore down my iMac and found that it had a 500GB WD Blue HDD. I want to upgrade the HDD but I would prefer if the upgrade was tom something like a 3.5" SSHD, such as this one: http://www.amazon.com/Seagate-Desktop-3-...
Is it possible to install said SSHD when the iMac came installed with a WD Blue? If not, is it possible to install a 2TB Seagate Barracuda or will it have to be a WD drive?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Did this hard drive have a plug in for the heat sensor?
von
Yes, the hard drive did have a temperature sensor. I assume you're referring to the 8-pin connector right next to the SATA power and data connectors?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes it can be done, but you'll need to swap out the sensor cable to the correct one for your drive. Here's the list of the P/N's for the different cables:
Cable, Temp Sensor, Hard Drive
  • 922-9215 - Hitachi
  • 922-9216 - Seagate
  • 922-9622 - Western Digital
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So how would I go about that? Should I buy the SSHD, then buy the cable (in this case the part number would be 922-9216) and then install the drive and plug the same cable in the iMac? And where could I purchase said cables?
von
It's not much more work to swap out the sensor cable. All you'll need to do is loosen up the logic board enough to fish out the old cable and slide in the new one. As to finding it just google it Apple 922-9216 there you'll find quite a few outfits that offer it. So, in a nutshell you'll need to order both the cable and the drive and put them both in.
von
Antwort hinzufügen
Muhammad Alwan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 662
