Samsung washer no power at all suddently
Hi, could someone give me a hint? This is Samsung front washer, model WF203ANS/XAC, about 5 years old. Never had problem but after we loaded it and believed it had worked for a while (could turn it on, seeing the led lights). Then we found it is dead and no responding to any buttons. The door was locked with clothes and water inside!
I have opened it almost everything and managed to take it front face off and got the clothes out.
I have measured the Noise Filter (DC29-00013A). Its input side is 121V and output side is 121V. The wall plug is 121V. At the same time, there is no any responses, or led lights on at all.
I am not sure if the Filter is good and working? do I need to replace it?
I have checked the water pump (inlet and outlet) and see nothing except water.
What else I should check? How can I know if the PCB (the main control board) is working or dead? There is no sign of burning on it or anywhere.
Please help. Thank you in advance!
Ist dies eine gute Frage?
13 Kommentare
Did you get it fixed and how? Thanks!
von Tru Tran
No it won't come on
von heidipippa1938
My washing machine went off mid cycle I got clothes out and drain water now the control panel won’t light up
von n.t.crowley
Did you ever get this issue fixed and what was the problem??
von Kaitlin Greatrex
Has anyone been able to determine what is wrong and how to fix it? My front load WF42H5200W is doing the same thing. I've already shelled out $350 to a repair man and an electrician, but it still stops mid-cycle, or won't turn on, or gets stuck in the locked position. I've had it since 2017.
von Becky Lewis
8 weitere Kommentare anzeigen
