cannot find a way to connect wifi
So i just got a cheap nice asus laptop/netbook today and i tried to find the wifi connections but i couldn't find it , i don't know where is the place can connect the wifi, is it don't have any wifi connection ? Some plz help me .
Ist dies eine gute Frage?
7 Kommentare
someone please help me i am !#^&@@ off right now i can not find any way to connect the wifi not even any symbol to see how to connect the wifi>
von jinxleebrown
I had this problem too. Wifi/airplane mode on/off. Restarted. Followed all the forums. Updated driver software. Network adapter - properties - minimum power consumption disabled. Yep all of it. Nothing fixed it.
Finally I saw on one forum which fixed it:
Device Manager (searched for it) - Under Network Adapters - Broadcom 802.11abgn Wireless SDIO Adapter - I disabled it then enabled it. It will prompt you "Are you sure you want to do it as it will cause it not to work anymore?" Yes. I'm not an idiot. Then immediately re-enable it. Mine already was enabled. But I turned it off & on again. After 1 minute wireless bar just popped up no issues. I didn't have to reconnect to my wifi, change any settings, login, or restart. It just did it. Yay. Finally.
Stupid thing. It's possessed. Had it 2 years. I'm getting something else. Piece of S really. You only get what you pay for.
Hope this helps anyone else's connections if all else has failed like mine had.
von Albert Einstein
Just wanted to say it did help me! Had the same problem, totally solved... Thanks a bunch!
von Twickenham0
Thanks. trying all of the obvious things and came across this
von mickey boaglio
Omggggg!!!!! It works! My problem was, I can't connect to the wifi, everything was visible, wifi connections and all but it can't connect. Then I found this!!! Thought my notebook will be wasted now. Been using it for 3 years.... thanks soo much :))
von Ysh D
2 weitere Kommentare anzeigen
