Zum Hauptinhalt wechseln
Harley-Davidson Sportster Motorcycles from 1986 to Present.
34 Fragen Alle anzeigen
Why can't I shift out o gear?
I have a first bike that has been in an accident with no apparent damage except to frame. I have good auto mechanical experience. None on Harleys.
The gear shift lever does not shift gears. Some thing is going on in the trans but no solid connections. No spring action on the lever. The bike is in gear and won't shift. What's broken?
Is there an online video or tutorial on inspecting for damage? I don't want to tear into something that requires special tools and equipment to result into taking a box of parts to a dealer.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
mine sometimes sticks a bit until I pull the clutch in and start the engine, then it starts shifting again. I imagine that some combination of rocking it back and forth, pulling the clutch and generally jostling as much as possible might have the same effect.
von
Einen Kommentar hinzufügen
2 Antworten
I'm afraid the shift shaft or shift fork plate/hook is sheared off inside and unable to rotate the shift drum. On the XL models, you'll have to remove the outer primary cover and clutch basket to get access to those parts.
War diese Antwort hilfreich?
Bewertung 0
My 81 is doing the same thing,I replaced the clutch ramp and Was adjusting the primary chain in 4th gear when I noticed I could Not shift into any gear? But when I engage the clutch I can rotate the rear wheel? Is my shift fork trashed also or something else ??? Thanks
Bewertung 0
1 Kommentar:
i have an 09 sporster XL1200c it shifts fine goes threw all the gears until i put the primary cover on then it dont spring back to the middle in order to shift again
von
Antwort hinzufügen
Old Bill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 37
Insgesamt: 2,528
