Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Angekündigt am 9. September 2014, ist dies das erste Gerät von Apple im Bereich der Smart Wearables. Die Reparaturanleitungen von iFixit beziehen sich sowohl auf die Apple Watch (Edelstahl) als auch die Apple Watch Sport (Aluminum).
181 Fragen Alle anzeigen
Will the Apple Watch sapphire digitizer work on apple watch sport?
Greetings!
I work as a repair technician and I am now looking into Apple Watch repairs.
One thing came to my mind: I'm sure people would, if they had the option, rather have their broken Apple Watch Sport Ion-X glass screens replaced with a sapphire glass instead of the Ion-X glass.
But.. Will the Apple Watch digitizer work on Apple Watch Sport?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Kommentare:
And you will be buying your sapphire screens from...?
von
Hi was my answer helpful? do you need any more help?
von
anyone know where to buy replacement glass?
von
How about this item. It includes the adhesive which is very important!
https://goo.gl/qpgruP
And just forget trying to replace only the glass. Replace the complete touch/lcd assembly and save yourself a nightmare.
von
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
4 Antworten
Gewählte Lösung
Yes, they have the same digitizer and lcd are interchangeable the only different is the surface mount crystal which doesn't effect performance.
War diese Antwort hilfreich?
Bewertung 2
Hey charkel, It should also be mentioned that the two parts may be interchangeable, but the water resistance of the device may possibly be at risk with this replacement. Please check out Is the Apple Watch Saphire Glass and the Ion Glass Interchangable? for more details.
Bewertung 1
Kommentare:
I would not offer the water resistance even though it might work. Just get a screen cover for the standard Sports glass.
von
I just replaced my friend's Apple Watch Sport screen with a sapphire crystal screen of an Apple Watch I bought on eBay, which was locked to an Apple ID. The repair was challenging and I bought the adhesive tape to adhere back the screen. Not sure if it's waterproof but the Apple Watch works fine with the new screen. Just FYI... I tried to repair just the glass on the screen with no luck. Replacing just the glass on the Apple Watch is a nightmare and not worth the trouble. Buy an Apple Watch on eBay like I did and replace the whole screen.
Bewertung 0
I am Porlah iRepair and offer using used Apple OEM screens because sometimes the screens alone are worth more than the watch. I would like to pinpoint that series 2 and 3 screens are not interchangeable. I experimented and they wont interchange even though they are similar. Stainless Steel and ceramic watches have different types of screens because the screens are a two piece. A regular replacement will still work. Also our goal is to maintain a watches Apple originality so it’ll be best to try to use plastic tools instead of metal.
Bewertung 0
Antwort hinzufügen
charkel wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 9
Letzten 30 Tage: 43
Insgesamt: 4,504
