Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3948 Fragen Alle anzeigen
Logic Board replacement part
Can I purchase a motherboard, unlocked /(from any network or icloud) for use of this device (iphone 5s 16gb) in UK from ifixit ?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
Android Fix Kits
Ein neues Display oder Akku sind nur ein Kit entfernt.
Jetzt kaufen
Android Fix Kits
Jetzt kaufen
1 Antwort
Hilfreichste Antwort
iFixit does sell logic boards. Find them here: iPhone 5s Logic Board
They are, however, carrier locked -- so would not be useful in the UK unless you paid the carrier to unlock them here. If the phone that the logic board was removed from is not under contract, the carriers are required to unlock the board by law. You'd still need to boot the phone to get the serial number in order to ask the carrier to unlock it.
Be careful though -- International phones may require different attennaes than you will find on a stock USA GSM logic board. You may not get proper reception.
iPhone 5s Logic Board Bild
Produkt
$29,99
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
I have noticed that many verizon LTE phones , which would include the iPhone 5S do come unlocked for use on other carriers by default. but since ifixit says it is locked to Verizon ,idk I guess not..... also an ATT motherboard can be unlocked for use with other carriers. the sprint motherboard can only be unlocked for use outside the US, and it is more expensive to unlock that an ATT motherboard. Buying the ATT motherbaord and unlocking it should work.
interesting to see that ifixit sells iphone motherbaords.
by
Antwort hinzufügen
gerryknoud wird auf ewig dankbar sein.
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Insgesamt: 955
