Zum Hauptinhalt wechseln
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
201 Fragen Alle anzeigen
Bad Wifi reception after LCD replacement
I bought a HTC One M8 with cracked screen. Today i replaced the LCD and i notice very bad wifi reception. Did i damage something or forgot something?
I don't know where the wifi connector is located, and can't seem to find the answer on the internet.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
I have the same problem now. If you know what to do, please write it down
von
Einen Kommentar hinzufügen
2 Antworten
hi
The problem is that you simply forgot to install the reinforced tape signal for Wi - Fi.
see photo ===>>
WiFi fix
https://s22.postimg.cc/islbn1s69/wifi_fi...
Thank you
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Also this can be caused by damaged antenna connector or cable in case anyone wanted to know, but most of the time like you said forgot to put back the Wifi antenna cable.
von
I need help. I changed display and i have poor Wifi signal. I connected all that needs to be connected. I think that i damaged cablr, but i don't now which one is for wifi. I will probably buy a full new set. Please if someone know which cable is for what text me. Thanks
Bewertung 0
Antwort hinzufügen
Gregory wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 745
