Zum Hauptinhalt wechseln
The Asus G72GX features a 17.3-inch high definition display with a 16:9 aspect ratio, released in 2009
Disable touchpad on ASUS laptop
How do I disable touchpad on Asus Laptop?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Check your Function or "F" keys. One of them should have a graphic of the touch pad with a line through it. Hold down the Fn key and press this one to disable or enable your trackpad.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
tried this and nothing happened. I need to disable the touchpad because it's making my pointer icon jump all over the screen when my hand/wrist touched the pad while typing. help
von
Check if ur Asus smart gesture is installed.
von
I've having the same problem Brent D is having. When I'm typing my pointer is jumping around the screen. I can't get the touchpad disabled. I have no idea how to check for Asus smart gesture installation. Laura A.
von
Fn + F9 used to work, but every windows update enables it again. This latest seems to have disabled this combination completely. It's very annoying and causing me to lose a lot of work.
Bewertung 0
1 Kommentar:
Hi If you are running Win10 have you got the latest ATK package and Smart Gesture software installed? Install the ATK package 1st before the Smart Gesture. Do not be tempted to install the other drivers. One problem at a time. If it ain't broke don't fix it!
Here is a link.
http://ivanrf.com/en/latest-asus-drivers...
See the 'Note' on how to install.
von
Antwort hinzufügen
Nancy Heinonen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 2,021
