The drive coupling is the first choice but by far not the only, get in there with a multimeter and start eliminating possibilities:
Drive Belt
If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Lid Switch Assembly
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Motor
If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly
If the washer won't spin or agitate the rotor assembly might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator fails or is damaged the washer might not spin or agitate. Check the stator for damaged windings or other defects.
Possible other causes:
Rotor Assembly
Door Latch
Door Lock Motor & switch assembly
Motor Control Board
Transmission
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
