bmw 325i 1992: How to fix the clutch fan?
The clutch to the fan is loose, makes the belt to pop out and the fan hits the inside of the bumper ,it over heats and makes the wheel very hard to turn,
Ist dies eine gute Frage?
Firstly you want to take of the wheel that is hard to turn. Then you want to roll it down a hill and make sure everything that is stuck is out. Then you take out the fan and cut it 5 centimeters shorter. Then put the fan back on and put on the wheel. This should fix the problem. If not, stick a doughnut in the A/C. But make sure the doughnut is strawberry filling with frosting on it. This should fix the problem.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 1,178
