Zum Hauptinhalt wechseln
7,9 Zoll Display / Modell A1432 / Verfügbar in schwarz und weiß / Angekündigt am 23. Oktober 2012 / 16, 32 oder 64 GB Speicherkapazität
How to fix my display not working correctly?
Hi,
Changing the glass of the ipad mini, when I finished the display won't work correctly. I just displays randoms lines and the bottom of the screen is all black.
I tried cleaning the connectors and pluging it again, but no success. Any ideas ?
here's what is looks like
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
It appears that the LCD is damaged. It is hard not to damage the LCD or digitizer when trying to do a glass only repair. Applying to much pressure, or using the incorrect tools can easily damage the LCD. Your display in the photo signals a cracked or damaged LCD. You will need a new display assembly (digitizer + LCD) to fix your device.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
Why is a new digitizer necessary? I have the same issue here, but if the vertical lines signify a damaged LCD, wouldn't that be the only thing to replace? Just trying to save $70 if I don't have to spend it.
von
Yes you would only need an LCD if the digitizer is undamaged.
von
Thank you, appreciate the assist!
von
It looks like you damaged the LCD while replacing the digitizer. What you will need to do is buy a new LCD for the ipad and carefully take the ipad apart again and replacing the lcd with the new one. The glass+digitizer you purchased is still fine and as long as you remove it without damage you can use it again when you install the new lcd.
Bewertung 1
how to repair my ipad mini,i cannot open my itunes only disable never working.
Bewertung 0
LCD is cracked.involuntarily you have applied too much pressure and LCD is broken. you should replace it.
Bewertung 0
Antwort hinzufügen
marcalexandreleger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 1,188
