Zum Hauptinhalt wechseln
Die dritte Generation der Samsung Galaxy Note Phablet Serie wurde am 25 September 2013 veröffentlicht. Es trägt die Modelnumer N9005.
247 Fragen Alle anzeigen
Unfortunately clock has stopped working
When i want set an alarm this message will show
Please help
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
I was also experiencing the same proble m but i found that the real problem is silent mode. If the phone is on silent mode then this error will occur when u set alarm. Simple solution is keep all the sounds on while setting alarm.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Yeahhhh... This Work. Thanks a Lot Dude....
von
I too experienced the issue "unfortunately, clock has stopped" after updating my phone to Lollipop. I called Verizon and they told me to do a factory restore, which I did. The issue still persisted.
I just called Verizon Wireless tech support back. The guy had seen this problem once before and found a fix for it. I haven't seen this fix posted on any website, but it worked immediately. Please let me know if this works for you
Go to Settings--Date and Time--Select Date Format, and then choose a date format. Once I picked 'regional' the clock worked without the error "unfortunately, clock has stopped"
I tried clearing cache and doing a factory reset, and it didn't work. You don't have to do this if this if selecting a date format works. Please comment and let me know if this helped you. I'm curious if this will work across the board. Maybe even for phones other than Samsung Galaxy S4. I'm stoked!
Bewertung 0
1 Kommentar:
My dear friend, after i clear the cache and restart my phone i tired for that message and finally i reset factory in my phone but before this i create an backup from my device, and next when i test my clock i saw that it's working!!!
Thanks for your time
Have fun
With best regards
Masoud taghavi
von
Have fun
With best regards
Masoud taghavi
Bewertung 0
1 Kommentar:
I did that too and now it works! :)
von
Go to setting, device,sounds and notifications, interrupt,sound - select sounds. This solve the problem for my note3.
GK
Bewertung 0
My clock not working why
Bewertung 0
1 Kommentar:
Please find the my clock
von
Antwort hinzufügen
Masoud wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 10,317
