Zum Hauptinhalt wechseln
The Motorola DROID MAXX is the successor to the Motorola DROID RAZR HD.
31 Fragen Alle anzeigen
After repair Phone is rebooting every 30 sec, and no picture
Replaced display assembly and now when plugged in the phone is restarting every 30-50 seconds in addition to the screen not working any suggestions plz!?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Randy's answer is probably going to fix it. You might want to go ahead and check all flex cables to make sure they're seated correctly. Also, make sure the power and volume buttons weren't put in a bind when you put the thing together. I have had that happen (I hate being rushed) and had to remove the mid-frame to fix it.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Mine did that after replacing the battery, and found the ribbon connection to the screen was not fully seated
Bewertung 1
Antwort hinzufügen
Heather Grant wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 128
