Zum Hauptinhalt wechseln
Veröffentlicht Januar 2015, Der XPS 13 Laptop ist ein Konkurrent des MacBook Air, mit einem randlosen "infinity" Bildschirm mit Touchscreen Option.
75 Fragen Alle anzeigen
Upgrading the SSD, will it be compatible?
I scrolled through the comments and saw that the required ssd m2 for this laptop (xps 13 2015) would be 80mm NOT the 60mm ones.
So will http://www.amazon.com/Samsung-850-EVO-3-...
Fit in perfectly and run perfectly with the bios and stuff?
My new to upgrading ssds. Would it be as simple as plug and play?
It is currently running ( samsung pm851 with 128gb)
Thanks in advance
Sheldon
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes. I just completed this exact upgrade just minutes ago. I got an external M2SATA to SATA adapter/enclosure at the same time I bought the new SSD (http://amazon.com/gp/product/B00SM0M5QC?... - enclosure instructions were horrible). I put the new SSD in the adapter and connected it to one of the laptop USB ports using a SATA to USB adapter I already had (http://www.microcenter.com/product/35793...). I wanted to retain the GPT partitioning with the support partitions and found the Samsung Data Migration software inadequate to do this (at least one partition was not recognized). I also looked at EaseUS ToDo, which also did not appear to have the needed capabilities. MiniTools Partition Wizard Free Edition (http://www.majorgeeks.com/files/details/...) performed the migration well. I did a disk clone keeping all partition sizes the same, moving the last, ~7GB, partition to the end of the new drive and then resizing the C:\ drive to consume all of the new space. The clone process took ~1 hour, with a reboot needed to clone the boot partition; I ended up with a 457 GB C:\ drive.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Can I just insert it then and clean install Windows from a bootable usb? I don't have a sata to usb convertor.. And I don't need those filss
von
I would certainly think so; I can't imagine a scenario in which it would not.
von
The XPS 9343/9350/9360 has one of the best SSD slots I had seen ever. It does not matter if it is PCIe/NVMe/SATA. They all run very fast. As long as it fit, the computer can recognize it and you can put whatever you want on it.
___
Formatting and initializing the drive can go as easy as Windows Disk Manager, or DISKPART for more advanced users.
Macrium Reflect is very powerful if you want to clone sectors.
Bewertung 0
Antwort hinzufügen
Yong Sheldon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 6,068
