Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1234 Fragen Alle anzeigen
Frage geschlossen
WHY? Dark blueish black screen. No apple logo. Did hard&factory reset.
Like many I cracked up my screen so I bought a new one. Although my screen was reaallly cracked it still worked and got the job done. I took off my old one and then decided I didn't have the time to do it all then, So I went to put my old one back on for the time being. After I did the screen began to light up in a dark blue but still nearly black color.... There was no apple logo or anything. I still hear the alerts for calls and messages tho, but again, there is no display of anything and the only way I can now turn the phone off is by disconnecting the battery. EVEN now after replacing my old screen with my new iCracked one it is still the same. I've done Hard&factory resets and checked all the connections numerous times. I even disconnected the battery and held the power button down for a little while and let it sit for a few mins, then reconnected and restarted and still nothing.. PLEASE HELP! Thanks..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
you knock off a capacitor next to the LCD connector on the logic board.
There is no way for you to fix this unless you know how to micro solder.
You can send it to http://mendonipadrehab.com/ for repair.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Hmm, That sucks if that's really the problem. I wonder how much that would cost
von
mendonipadrehab.com they will be able to fix it for fairly cheap.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 301
