Zum Hauptinhalt wechseln
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
218 Fragen Alle anzeigen
Frage geschlossen
lines on display after lcd replacement
I am working on replacing the digitizer on my iPad 4. I believe I reconnected everything properly, except when I power it on to test it before reassembly all I can get out of the display are a series on horizontal lines. I tried unplugging and reconnecting the cable numerous times to no avail, I noticed when it is laying in the bezel it Almost seems right. I'm wondering if the metal contacts on the middle of ribbon cable, as in the plates not where the cable terminates, serve a purpose or have I possibly done some damage. Thanks for your help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
It is more than likely you have damaged the Lcd, replacing the Lcd should solve your issue. :-)
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Sure was the lcd, replaced it and was good to go. Thanks!
von
No problem :) make this your chosen solution since it was correct :-)
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 112
