Zum Hauptinhalt wechseln
The Samsung HLM or HLN series is a line of projection televisions.
29 Fragen Alle anzeigen
My picture is very dark
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Serial # B19G3CKL501709L
MODEL # HLS5087WX/XAA
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
hpimidwest, it is possible that it is your bulb.It could mean that your lamp is old (4000-5000hrs) but it could also be your ballast. As the lamp gets older, it requires more voltage to spark or ignite. If you still have a picture, just dark/darker you are a bit in a catch 22 situation. You can buy a new bulb and hopefully that will resolve the issue, but if it does not, you would have to replace the ballast. You may end up purchasing both. There are numerous variation of ballast and bulbs. We'd need the exact model number to help you out further.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
my tv is okay, after a little while, its getting dark, and nothing at all...it has sounds, what is the problem? thanks
von
One of the bulb needs replacement if not calibration. If you are able to take apart, you can test which one is out. If you can't take apart and it's under warranty, get it replaced for free.
Good luck.
Bewertung 1
1 Kommentar:
what bulbs are you talking about
von
no picture has sound wont stay on
Bewertung 0
1 Kommentar:
drahming 415 you posted a question as an answer to a different question. Your question can now be found here want say on,no picture,has sound
von
Antwort hinzufügen
hpimidwest wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,724
