craftman lawn tractor 42"
rear tires will not move belt ok can not even push tractor
Ist dies eine gute Frage?
Have you had one or both of the rear wheels off? There is a small metal stick (they call a key) that needs to slide into a slot on the wheel and then put back on the wheel rod. If this is not in place, the wheels will not turn. They are called a key and that is what confused me. When I removed one flat tire to fix, fortunately the metal rod stuck inside the wheel slot long enough for me to remove it and keep it safe. Also... do you have a transmission rod at the back of the lawn tractor? The metal rod needs to be pulled out to push tractor by hand and pushed in to drive it. It won't drive with the transmission rod out.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 55
