Zum Hauptinhalt wechseln
The Sega CD I, A.K.A. The Mega CD I (in Japan) was the original Sega CD unit released in 1991.
My Mega CD1 won't read Game CD, but can play audio CD.
Hello. My Mega CD1 won't read Game CD but audio CD play without problem.
The CD-ROM icon never appaeared in the menu.
Is this an optic problem and supposed to be tuned or is there problem in other parts?
Thank you in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
adityarai2001, sounds like an issue with the laser. I would try to clean the laser with a professional clean kit first. You can also disassemble it by using these guides and clean it. If that does not work you most likely will have to try to replace the laser assembly.
War diese Antwort hilfreich?
Bewertung 1
If you have a multimeter check the ohms of the laser should be at 700 ohms or .700 k ohms make sure not to adjust the Focus pots
Bewertung 0
Antwort hinzufügen
adityarai2001 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,113
