Zum Hauptinhalt wechseln
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 Fragen Alle anzeigen
Is there a place for a sim card?
There is a slot for a micro sd card, but I do not see a slot for a sim. Do I need to take the back off to access it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 14
4 Kommentare
is ka file kaha pa hae sent gmail
von
Is there any way to have and insert sim card because I have the same tab like sarah
von
what about Galaxy tab E T560 SIM card insurted are not paz gu
von
When I insert sim card into my Samsung Galaxy 3 it still says to enter a sim card..
von
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
If your tablet supports it the sim card will be located on the same side of the tablet as the sd slot however not all tablets are made to support a sim card . This video shows how to change it out if its supported
https://www.youtube.com/watch?v=Iypr20hI...
Hope this helps
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
That video was useless.
von
Does a galaxy tab a sm-p550 have a sim slot
von
really this was useless
von
Hilfreichste Antwort
Hey Sara, it seems like you have a Samsung Galaxy Tab 3 7.0 P3210. This has no sim-card slot and is the Wi-Fi only tablet. The Samsung Galaxy Tab 3 7.0 P3200 has a slot.
-Let me know if this helps.
Bewertung 8
3 Kommentare:
But, it's showing a message on the screen which reads "insert simcard"
von
Hi I have a Samsung A6, does this have a sim slot?
von
Hi Lillian I have gobii tablet does it support simcard
von
what about changing the battery of a samsung tab 3, mine is nolonger working well and i want to change it but its seeming impossible
Bewertung 1
1 Kommentar:
Take it in to a Samsung shop or similar, and explain the issue, they should be able to replace the battery for you.
von
Just download firmware sm-t116nu in your tab and use your micro sd card slot to your sim
Bewertung 1
2 Kommentare:
does that really work?
von
That is brilliant....If there is an adapter from sd to sim then why can't software make it work. I have not tried this but it sure does sound plausible to me. Kyle, you are a scary kid. Kudos. I'm not sure but I think I'll give it a whirl because although I don't seem to have an adapter I do however have a pulled sim slot and a soldering iron. The software I'll be trying is this one: https://firmware.gem-flash.com/index.php...
von
The sim card goes in a slot next to the memory card . If you don't have this then you don't have a phone facility
Bewertung 0
Hi
I have the t820 model with this double slot.
Does this mean my tablet is sim ready?
When I brought it 2 years ago the shop assistant said these tablets will take sim
I'm guessing I need to buy a new holder?
Bewertung 0
2 Kommentare:
thats the same as mine. did yours come with the keyboard? its very helpful....
von
i got the sm-t820 also with the double slot but my holder is like yours with only the sd slot holder.. did you get a double holder and if so did it work? also my sd card just stopped working.. any suggestions??
von
I have a Samsung tab 3, would like to add this device to Verizon, right now has a sprint SIM card, how do I address the issue?
Bewertung 0
Antwort hinzufügen
Sara Wilson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 68
Insgesamt: 94,978
