Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3949 Fragen Alle anzeigen
Phone overheating when camera is on
Hi,
I have a problem with my iPhone 5s. I dropped my iPhone and the screen was cracked. After the drop, my rear camera and flashlight stopped working. I thought if I replace the screen, the camera might start working again but no luck. If I try to turn them on, the top right corner of the phone gets extremely hot and I need to turn my phone off to stop the heat.
Anyone know what might be the problem and how to resolve that?
Thank you.
K.V
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Android Fix Kits
Ein neues Display oder Akku sind nur ein Kit entfernt.
Jetzt kaufen
Android Fix Kits
Jetzt kaufen
2 Antworten
Sometimes on electronics the thermal paste can get dried up. Sometimes it's best to open it up, re-paste the thermal, and put it back together. Although what i think is happening is the camera is stuck on permanently and that is causing the heat ups. Hope that helps!
The camera part on ebay is about 10$.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Thanks for your reply. The flashlight is also not working. Do you think when I replace my rear camera, then it all should be OK?
by
The camera and the flash light are correlated parts. If camera stops working, the flashlight doesn't work either. Therefore, fixing camera issue resolves the flash light. You can get the required part here. Check out similar vendors selling the same items at the most competitive price. This will benefit you.
Bewertung 0
Antwort hinzufügen
Keiro Vantsi wird auf ewig dankbar sein.
Statistik anzeigen:
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
Insgesamt: 1,132
