Zum Hauptinhalt wechseln
Das erste Modell des iPhone, Modell A1203 mit 4, 8 oder 16 GB Kapazität und einer Aluminiumrückseite. Die Reparatur erfordert erhebliches Hebeln und möglicherweise auch Löten. Diese Seite soll Nutzer:innen bei der Fehlersuche und -behebung helfen und sie bei der Suche nach Hilfe für das iPhone 2G unterstützen.
224 Fragen Alle anzeigen
iPhone 2G (1st Gen) 8gb back panel repair
As you can see there is major damage to my original 2G iPhone 8gb back panel and trying to find a replacement part has been like trying to drill a hole in my head. Do you all know any affordable options for a repair part?
I can only find ones that are like $35, which is the same price I just bought the new LCD screen WITH a digitizer for this. I don't understand how that is possible. I will be replacing pretty much everything on this phone at this point.
The front bezel, LCD screen, antenna cover and now the battery cover back panel. The only reason I am not selling as is, is because the touch screen will not work properly and does not slide, which I believe has to do with the LCD screen being cracked.
However, it could also be a problem with the logic board too, maybe? Won't know for sure till I replace the LCD screen, unless you all have a better suggestion?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I found a great video on how to repair the back panel but it is in German. I plan on, once I get a cheap replacement back panel, to do my video but here is the one I found: https://www.youtube.com/watch?v=kqka3Vqp...
Good luck with your repair!
von
Einen Kommentar hinzufügen
1 Antwort
go and serch it up on alyepris
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
mmcney1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 860
