Zum Hauptinhalt wechseln
Fourth generation Samsung Android tablets. Released in April 2014.
358 Fragen Alle anzeigen
Problem with my battery
I can only use my tablet (Galaxy Tab SM-T530) when is charging because while it is not charging it keeps on crashing and not booting
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Battery needs to be replaced. iFixit does not have the guide but sure you can find something online. When batteries are not performing well you will get some of the problems mentioned in your question!
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
That wasn't helpful in the slightest.
von
Hey.. I said battery needed to be replaced most likely :)
von
This is most likely a problem with your battery, I wouldn't say it's crashing, It's run out of Battery.
If you can take it off charge once it's running, that'd be strange.
Also I recommend if that fails, First, try replace the charger, if that does the samething. Sorry to say but you might have to replace that battery.
Goodluck :)
Bewertung 0
Antwort hinzufügen
Abdel Rasul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 896
