Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1232 Fragen Alle anzeigen
Why does my phone only go on apple logo
I have an iPhone 5s, and and a few months ago my apps started crashing but i thought it was because lack of space, and i can restart it and then it works again. Then just today, a few hours ago one of my apps crashed in middle of me using it and so i went to restart it, once i turned it off I pressed the power button to turn it back on and it only went to the apple logo screen for about 5-20 seconds then it turned off. I have been trying to turn it on but it keeps doing the same thing. It doesn't do anything once it is plugged into my computer or charging. No matter what I do it only goes to the apple logo screen then turns off. I can't update it, restore it or do anything. Is there a way to fix it? Or possibly get my pictures off of it. I have important pictures i can't loose.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Has the phone been drop before? has someone previously worked on? Was the phone purchased new? are you using a original apple charger?
von
@Sunny (I have no idea how to tag you)
It has been dropped before.It is cracked and during winter it has gotten wet so water may have gone through the cracks. I put it in rice over night whenever any water got on it. The phone is actually kinda new. I got it around November of 2014 and yes I am only using an apple charger for it. No work has been done on it, this is the first thing that has gone wrong with it.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi hannah,
So judging from what you said, it seem like the phone is effected by liquid damage. liquid damage can be spontaneous, sometimes the effect doesn't show right away. So in something like this you should bring it to a shop and ask for a free diagnostic. but if you want to open it up and post some picture to see if i can find anything i can do that for you. let me know how it goes. if it helps please choose my answer.
Good luck!
War diese Antwort hilfreich?
Bewertung 1
Hannah Dollens, for now I would suggest that start off by turning it off. Do not try to turn it on, to charge or to sync it. This could potentially make a bad situation worse since it could shorten more components on the logic board out. Disassemble your phone by using this guide. Clean your phone with 90%+ (or better) isopropyl alcohol. Use this guide to clean your phone. It was written for a 3G but all the steps are pertinent to your phone as well. Inspect your board for any missing or damaged components. Remove all the EMI shields to clean the board. Once properly cleaned, replace the battery and Lightning connector, then reassemble and re-evaluate. Water damage is the hardest to diagnose and to repair since almost any part can have failed.
iPhone Bild
Anleitung
iPhone Wasserschaden reparieren
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iPhone 5c Logic Board Bild
Anleitung
iPhone 5c Logic Board ersetzen
Schwierigkeitsgrad:
Mittel
1 - 2 hours
Bewertung 1
Antwort hinzufügen
Hannah Dollens wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 191
