Zum Hauptinhalt wechseln
Samsung Galaxy smartphone featuring a large display , and large font size.
49 Fragen Alle anzeigen
I'm only getting the samsung logo and phone is not working anymore
My phone went black then i tried to charge it and after charging, it would no longer turn on. All i'm getting is the Samsung Galaxy Grand GT-I9082 logo. I tried to remove the battery and turn it on/off a dozen times already but still the same result.
Is there a way to back up my data in the phone should i need to reformat it?
Please help.
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I have the same problem but with my Samsung Galaxy Tab 2
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
When smartphone freeze before standby mode it means it has software or booting problem . All you have to do is flash it with newer firmware then your problem will be solve. Only do if you are what are you doing because miss handling can lead to brick your device.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
kiddlez75 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 872
