Zum Hauptinhalt wechseln
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Fragen Alle anzeigen
Frage geschlossen
Want to upgrade to an SSD, or Hybrid drive
I'd like to upgrade to an SSD, or Hybrid drive.
Elsewhere on your website you say that for a hybrid drive, the manufacturer of the new drive must be the same as the original (mine is Western Digital). Your hybrids are Seagate :-(
Can I upgrade to an SSD?
Thanks
David
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is nothing stopping you from putting in any manufactures HD (or SSD) as long as its SATA II (3.0 Gb/s).
You are noting an issue in a different series of iMac's that use an internal thermal sensor within the HD. Apple has used three different methods within their iMac's to access the HD's temperature.
This model uses a thermal sensor that is stuck onto the hard drives case. Review this IFIXIT guide: iMac Intel 20" EMC 2266 Hard Drive Replacement. Jump down to Steps 19 - 20 where you'll see its removal from your current drive.
As to putting in a new drive:
You'll need to get a HD (or SSD) that is able to run in a SATA II (3.0 Gb/s) system. The Seagate SSHD IFIXIT sells auto sets to the systems SATA port speed. Not all drives are able to run at SATA II so be careful!
But before you do anything make sure your systems firmware is up to date. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers.
War diese Antwort hilfreich?
Bewertung 4
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 121
