Zum Hauptinhalt wechseln
Erschienen im Frühjahr 2014. Ausgestattet mit einem 5,5" Bildschirm. Ursprüngliches Betriebssystem war CyanogenMod 12S. Modellbezeichnung "ONE A0001"
110 Fragen Alle anzeigen
Where is the screen connector located?
Hello,
I recently replaced my Oneplus One battery, my phone now completely works but the screen does not, it is always eitheir OFF or only display black. I might have messed with the screen connector but I don't know wich one it is so if anyone could tell me so that I can reopen the phone in order to reconnect/clean the connector :)
Thank you !
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know!
luyten.mathieu@gmail.com
von
Einen Kommentar hinzufügen
3 Antworten
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know! luyten.mathieu@gmail.com
War diese Antwort hilfreich?
Bewertung 0
soft drop screen is on but hap tics touch will not respond. who fixes these? must be connection problem
Bewertung 0
Screen connection is on top by the camera. F.Y.I if you didn't touch the screen connection then it's not the issue..
Bewertung 0
Antwort hinzufügen
Florent Noel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 295
