Not booting after top case replacement?
So, I'm previously certified as an ACMT for an Apple self-servicing and would appreciate only others with likewise experience to respond to this question.
This machine was brought to me after having a run in with a glass of wine.
I was able to definitively conclude that the only damage to the machine was the power button had shorted out. I was able to jump it, get the machine to boot, confirmed all components and other keys were working, ran AHT, etc.
I went ahead with a top case replacement (without battery), opting to make an attempt to remove (and reuse) the battery with a heat gun (and some patience). Upon reassembling the machine, it wouldn't boot, post, chime, etc.
With the bottom case removed and everything exposed, I observed that the fans would kick on, but they'd just cycle on and off again.
I assumed I'd damaged the leads between the battery cells and ordered a "new" battery from an eBay vendor.
The item that arrived seemed to be a new part and came in the right packaging, but was marked with a serial number and had clearly been pulled out of another machine as the frame between the cells and the controller circuitry/connector was bent.
I installed the "new" battery and yielded the same results.
I disassembled the entire machine again, just to be sure I didn't miss anything when reassembling. Everything looks perfect, aside from the possibly defunct battery.
Anyone have any brilliant ideas or suggestions?
PS, this is the vendor the top case came from:
http://www.dvwarehouse.com/Apple-Parts-c...
They appear to sell brand new Apple Service parts to those who don't have access to GSX
Ist dies eine gute Frage?
1 Kommentar
Dump the heat gun. Use a syringe with a couple of cc's of methanol to loosen the battery glue. I comes out undamaged in five minutes.
von mayer
