Home Button Not Working
I'm having a problem with the home button on a 32gb iPod Touch 5. When the home button is pressed, nothing happens. However, if I pull the screen up and press the home button flex cable dome, it responds normally. I've tried replacing the plastic home button and rubber gasket, first transferring the original metal contact disc, cleaning the metal contact disc and home button dome with denatured alcohol and I made sure that the LCD assembly is seated back into the frame properly, etc., but nothing is working. What could be wrong? Can someone out there help me figure this out?
Ist dies eine gute Frage?
Did you ever find a solution to this? I'm having the same issue. It almost seems like there needs to be a piece protruding from the (interior) home button that contacts the metal plate on the (exterior) home button.
von tirgang
Hmmm, any insight on this, my iPod seem to be the same, the internal button work if i use a point to poke it but it does not when i press from the home button itself...seem like a small piece is missing between the home button and the switch's middle.
von William Lam
