Zum Hauptinhalt wechseln
The 2000-2006 BMW X5 models were the first generation (E53) of BMW's sport crossover years. The X5 was first released in 1999 for the 2000 model year and featured all-wheel-drive with either an automatic or manual transmission.
10 Fragen Alle anzeigen
Why is my crankcasae vent valve smoking
there is smoke coming (from the crankcase vent valve) out the tail pipe
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
What color is the oil . Black or brown like chocolate milk
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You'll want to take a look at the TSB / SI B 11 08 03. It's a well-known problem for this era of BMW cars including X3 and 5 Series.
Here is a copy that I found:
http://chrisparente.com/Images/530/CCV-S...
By the time I identified it on my X3, I had already blown a head gasket, but hopefully your X5 will avoid a similar fate.
War diese Antwort hilfreich?
Bewertung 1
If your engine is smoking out the exhaust, and sucking oil into engine, which I had happen, it is usually a sign that the two CCV hoses which cross over the back of your engine over the intake tubes if engine cover is off on the 4.4 motor X5’s, squeeze hoses, if they are spongy, this is indicator they are restricted and when this happens they suck oil into engine cylinder, as crazy as that sounds, it happened to me. Left side exhaust only. I replace all components and hoses, never had an issue since with over 100K miles driven.
Bewertung 0
Antwort hinzufügen
steven shortridge wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 475
