Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
671 Fragen Alle anzeigen
Screen heating temperature measurements
I have done a few smartphone screen replacements, and now I'm looking at this iPad mini, and I was wondering if there is a specific temperature to heat the edges to. I have an infrared heat scanner that makes it easy to get a reading on the temp, and they are cheap and readily available, so is there a temperature range that should be applied to the screen, and other tablets and smartphones.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I think I've heard people say generally not to go above 180F for any screen. But I think that's even a bit high. When I use my heat plate to separate LCD's, it's set to 60C(140F). Personally, for using a heat gun I go by touch to see if it's hot enough. I know it's not exact, but for me, if I can keep my finger on the screen for about 3 seconds before it burns, then I know it's perfect. I've been using that method for a couple years now, and on hundreds of screens. I would say just don't break 160-170F and you should be just fine.
War diese Antwort hilfreich?
Bewertung 19
Antwort hinzufügen
srp204 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 14
Letzten 30 Tage: 63
Insgesamt: 12,100
