Zum Hauptinhalt wechseln
Repair guides and support for water softening systems.
4 Fragen Alle anzeigen
Pipe draining so much water and water softener is making a noise.
I have a water softener Pro E Series E-70. It seems to be draining water to my laundy room. there is an extra white pipe . the pipe has been going for 1 hr and at the same time the water softener is making a loud noise. Is this normal?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
This is normal.
What happens during the regeneration process? During the regeneration process, the water softener floods the resin with brine water, thereby “cleaning” the hardness minerals off the resin and sending them down the drain. The softening resin in the water softener is now clean and ready to soften water again.
War diese Antwort hilfreich?
Bewertung 2
hi , check the drain line , locate on the back of the valve , make sure the connection is secured with either a hose clamp or threaded plastic compression nut. Then make sure the drain hose is secured to a drain tube shared with the clothes washer or secured to the drain sink and the drain isn’t plugged( it would be over flowing ). The Brine tank where salt goes has a 4 inch tube with a cap and hose attached to it, this is the brine fill valve, some times it can get stuck and if so the valve wont shut the flow to the brine fill process of the cycle. Most models have an over flow drain valve that in most cases does not have a drain hose attached thus draining to the floor. Lastly most systems recharge in early hours of the morning when no to little water is in use as if water is run during cycle the hot water tank will fill with hard water. You may need to reset the factory settings which usually is easy to do and check the drain lines as well as the valve it should fix the leaks, good luck
Bewertung 0
If the drainage line is attached higher than the water softening unit, check that. Twisted pipes may obstruct the drainage system and result in poor drainage. Don't forget to check the exit end because it can be submerged and obstruct the brine's smooth flow.
Bewertung 0
Antwort hinzufügen
pamelabas81 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 54
Letzte 30 Tage: 166
Insgesamt: 17,895
