Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
amarante have you replaced the speaker with a new one?
thnx for the suggestion but no need to change a new one because the speaker is still have a cracking suond.... the problem is contact points between the positive and negative live,,no deflection in both pointswhen i test in multi-tester ?any help?
von oldturkey03
von amarante
