Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 GPS not working
Hi,
I have an iPhone 6 and suddenly the gps function stopped working.
If I turn on my TomTom gps it shows "Poor GPS Reception". Sometimes my location is found for a minute and then again it's gone. I've changed the plastic antenna on top of the iPhone without any result.
Is there anything more i can do? I'm pretty sure that it's a hardware malfunction because i did everything i could with the software.
Thx for your help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
5 Kommentare
Hello mattis, before touting hardware try to fix by software, have you update your phone to ios9?
von
Yes, as I said in previous post, I did everything I could with the software. Restore, update, dfu, reset network settings, ...
von
See this thread for the fix!
GPS & Bluetooth work sporadically.
von
I discovered a crude solution. Ive noticed that because of wear and tear, my iPhone 6 "sandwich" is a little loose. There is some play on how the screem is attached to the body. Whenever my gps or Bluetooth is weak, i press on the screen to "compress" the phone. Boom. Gps signal restored.
von
My GPS had intermittent issues and then finally stopped working. Read a number of different forums that suggested changing the system settings, but nothing worked. Best thing I did was to download a GPS diagnostic app for $3. Turned out there was not satellite reception, which pointed me to an antenna issue. Ordered a new antenna and replaced it, GPS now works perfectly. Could have been that the tiny coax connections came loose and just needed to be pushed back in place, but as long as I had to disassemble the entire phone, it was easier to just replace the part.
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
If you restored your network settings and checked all the hardware then you have no more options left. Mine was swapped by Apple under warranty
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
For me - replacement of "WiFi Antenna Signal Flex Cable Ribbon " increased significantly wifi and gps sensitivity.
Bewertung 1
Nobody....? Still looking for the solution
Bewertung 0
I have same problem.
Message: Try to go outside but i was outside. After short time: Can not get GPS signal.
Hope somebody find this out
Arne
Bewertung 0
I am having the same Issue also noticed it shows poor wifi connection even though I know it is a strong signal
Bewertung 0
2 Kommentare:
Wifi and GPS use the same antenna, so probable there is a problem with it.
von
replace wifi antenna and cable - sure fix
von
check this part or change antenna two cable up and down
Bewertung 0
Antwort hinzufügen
Mattis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 13,979
