Zum Hauptinhalt wechseln
The LeapPad Ultra is an education based tablet developed for kids of the ages 4-9. It was released Summer 2013 with an MSRP of $99.
My LeapPad isn't charging
Even when I plug the charger into the LeapPad it still doesn't charge? What's wrong?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 18
36 Kommentare
I actually solves this on the leappad epic. Removes the 6 screws from the rear cover and 1 screw by the stylus. Removed the battery, held down the power button to discharge and remaining power. Reinstalled the battery charges just fine now.
von
I had the same problem with the Epic not charging. I tried what you said but the battery won't come out. It's apparently glued in somehow. I don't want to damage anything so didn't want to use tools, etc to accomplish this. I did detach the battery plug and re-attached but it didn't solve the problem. I have contacted Leapfrog to possibly help with a solution.
I wondered if using a charger that didn't come with it was the problem? We lost the original so just use a basic phone charger. I assume they're all universal but could be wrong!
von
My son pulled the charger out of his leapfrog epic tablet and broke the prongs inside the tablet where the charger connects. So now I have no way to charge it. Anyone know another option to charge it or is it trash now?
von
I left out a tip on the battery removal it has 2 piece's of double sided sticky tape under it. The stick just slightly out so you can remove them like a 3m command strip then the battery comes out
von
I did what he said and this work for mt just in case anyone else is having this problem!
von
31 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
This issue could be a damaged battery or a damaged charging port. Try to switch out your battery with another one to verify the issue. To do this, check out our Battery Replacement Guide. If the LeapPad still isn't charging properly, then you will have to replace the Charging Port.
War diese Antwort hilfreich?
Bewertung 10
4 Kommentare:
Where would you find the battery replacement guide? My leappad 2 is not charging at all as well. I have it on the usb pord, there is no charging light coming on but when I press the power button to try and turn it on, it will just blink green once and still stay off. What does this mean?
von
All guides are in process and in private at the moment. The battery replacement guide will be posted to the public very shortly.
von
Please refer to our new device page for any questions. LeapFrog LeapPad Ultra
von
Hi, I have this same exact problem. What did you do to fix it? @KAITLYN FITZGERALD
von
I actually solved this on the leappad epic. Remove the 6 screws from the rear cover and 1 screw by the stylus. Remove the battery, hold down the power button to discharge and remaining power for 35 seconds. Reinstalled the battery charges just fine now.
Bewertung 6
11 Kommentare:
removing the battery and holding down the power button for 35 seconds and then puting the battery back in worked thankyou our childs tablet has been dead for weeks she is so happy it works again
von
Glad it worked it happened 2 our daughter 1 day out of warranty. Its been fine since i posted this. Left out the battery removal tip. There is 2 pieces of double sided sticky tape under it. They stick slightly out and can be removed like 3m command strips. Then the battery comes out. Works just fine without them when you put the battery back in.
von
Do I unplug the battery jack as well to perform this discharge??
von
Thank you, thank you, thank you! Our epics have a lot of my kids schooling apps on them. I didn't have to remove the battery. I only had to disconnect the wire running from the battery to the tablet. Now it is charging like a champ. Thank you again!
von
I tried this advice and it worked the first time. (Thank you!) A few months later, it stopped charging again. I followed the same advice, but this time also removed the wire, but it's still not charging. Please help!
von
6 weitere Kommentare anzeigen
our leapfrog epic tablet stays on 1% , even if its on the charger all night , it just stays on 1% , its like it is infact fully charged but isnt saying any other percentage other than 1.
Bewertung 1
3 Kommentare:
Same with my Kid's LeapPad3. It keeps charging only 1% even when the battery indicator shows Green Light. Its not even to 3 months they started using it.
Thanks
von
I actually solves this on the leappad epic. Removes the 6 screws from the rear cover and 1 screw by the stylus. Removed the battery, held down the power button to discharge and remaining power for 35 seconds. Reinstalled the battery charges just fine now.
von
my child leap start will not charge it only came with batteries when I bought it but has an outlet for a charger. Someone please help me get this thing to working.
von
Diese Antwort bezog sich ursprünglich auf eine andere Frage.
I my son just recieved it for xmas. And it just stopped eorking i tried the removal snd its back on. I thought i had to replace the whole item. If i had to would i be able to transfer the apps i purchase on to another ?
Thank you
Bewertung 0
1 Kommentar:
It worked thanks 👍
von
Antwort hinzufügen
Rocky Hirsch wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 40
Letzte 30 Tage: 151
Insgesamt: 64,743
