Zum Hauptinhalt wechseln
The iBook G3 was unveiled in July 1999 as Apple's portable computer for consumers.
What do I replace the original thermal materials with?
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Good question +
von
Thank you, I'll give that a go.
Randy
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
von
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
von
Antwort hinzufügen
randy3833 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 2,368
