Zum Hauptinhalt wechseln
The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
16 Fragen Alle anzeigen
wifi doesn't work on padfone 2
Hello! after i have bricked my telephone, i was able to repair it, and i re install the lastest firmware, all works, but no wifi!!!! i think it's a software's problem.. it see the networks, i try to connect, but nothing, only "connecting" , and stop.. how can i solve it? i have changed some firware, uffical and rom.. re install the wifi driver? but how? thanks..
i attacched this screen for some informations..
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
hvae you installed CyanogenMod (custom ROM)? which OS is currantly running on your phone ?
von
4.4 official, no cyano, i tried other rom with 4.4 or 4.1.. but nothing
von
Einen Kommentar hinzufügen
1 Antwort
Dear psycho91,
Wi-Fi TRX not functioning on your phone. that is the reason to get RSSI -200 (Ordinary Wi-Fi RSSI range is -20dbm to 120dbm) you will have to replace Wi-Fi + BT module on your logic board.
Vocabulary
RSSI means Received Signal Strength Indicator
TRX means Transceiver
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
thanks, but i try in another house, and work, i went to mine and work... for now.. yesterday same problem.. don't connect!!! it's probably a software problem
von
Antwort hinzufügen
psycho91 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 445
