Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
283 Fragen Alle anzeigen
MacBook Air is not booting with the battery attached
I have a MacBook Air from early 2014. The problem with the MacBook is that it won't boot if the battery is plugged in. It will reach the Apple logo and complete about 1/3 of the loading bar and then it will reboot over and over again with the same results. As soon as I disconnect the battery it will boot normally. The magsafe LED won't come on at all in both cases. I have tried replacing the DC-in board and another magsafe adapter without any avail. Could somebody help me out? Is this a problem with the logic board?
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
The MacBook is completely dead right now. It won't boot at all anymore. No sign of life.
von
Einen Kommentar hinzufügen
1 Antwort
It looks like a new I/O series cable needs to be used that connects your magsafe board to your logic board. You can get this fairly cheaply on ebay or similar - even ifixit directly. Replacing this cable usually rectifies the other issues, especially if your fan is running loudly at all. Alternatively it could be your SSD - if you can try another - do.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Pascal van Dooren wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 122
