Zum Hauptinhalt wechseln
Alles was du brauchst, um dein iPhone zu reparieren! Von den neuesten iPhone 15-Modellen bis zum allerersten iPhone überhaupt - bei iFixit gibt es kostenlose Anleitungen zum Reparieren und Zerlegen für jedes iPhone und dazu auch die besten Ersatzteile, Werkzeuge und Tipps in der Galaxis.
36444 Fragen Alle anzeigen
Frage geschlossen
Adhesive goes inside the lcd
Hi guys, i fix phones for living
Well, whenever I replace the glass on iPhone LCD, loca goes between the screen and back light and it always indicate obviously glue underneath,
So I remove the back light and put a faulty light on temporary bases, and after sticking the glass just solder them back together but it make me annoying sometime cleaning and soldering again Nd again,
Can any give me solution for that please
Regards
Aqi
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The solution is called "OCA".
Do not confuse it with "LOCA"!
While LOCA is a Liquid adhesive, OCA is like a sticker.
You will need one to two machines to attach it, but its worth the money.
Just look at YouTube for "iPhone OCA" and you will get the rest.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I know bout OCA in which you need autoclave for removing bubbles but it's not studying me as when you drop your phone with OCA adhesive on LCD , there are changes you brake the screen quickly, or when it's already changed the glass with OCA and you break the glass again, hard to remove the OCA again.
That's why I like LOCA. You can put as much shock absorbing in that as much you can't do with OCA
von
You can also use some "tricks" to stop running LOCA between LCD and backlight:
First trick is:
Silcer Conductive Paste, as seen on this youtube-video:
watch?v=4DXHbPMoXG8
Second trick ist:
Use some "dough" (like play-doh) to seal the gap between backlight and LCD, then use LOCA and after curing under UV-Light, remove the play-doh (dough).
You could also use some sticky tape to seal the gap between LCD and Backligh to prevent LOCA running in between...
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,085
