Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
313 Fragen Alle anzeigen
Frage geschlossen
Keyboard doesn't function correctly.
I have some problems with my keyboard. The volume goes up every time I press the spacebar or some thing pops up unexpectedly on the screen when I type. Does the keyboard have any problem? Or is it a software issue? Can anyone show me how to fix it? And what's the cost gonna be?
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Need a bit more here. Did you get your system wet some how? Spill a drink into the keyboard or set the system down on a wet surface?
von
Are you up to fixing this your self? This is not an easy repair as you will likely need to replace the upper case which is were the keyboard is mounted.
von
Where should I get it fixed? I'm located in Dallas, Texas.
von
I didn't get any liquid dropped in it.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
To help isolate the problem, hardware or software, start up in Safe Mode by holding down the Shift key on start up and let us know if the problem persists.
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 88
