Zum Hauptinhalt wechseln
This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
10 Fragen Alle anzeigen
Toaster Oven won't turn on
Why doesn't my toaster work when I turn the knob on?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Make sure Timer is in 'Stay On' position otherwise oven will not come on!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This could be a number of things.
  • Inspect the cord for any cuts or exposed wires
    • If the cord is damaged it should be replaced before anything else
  • Make sure that it is plugged in and that the outlet it is being plugged into is working
    • It can be checked by plugging in something that you know works into the same outlet and turning it on
      • If the outlet is not working, then that is probably the reason the oven will not work
  • Damaged internal wiring (This is very unlikely unless the oven has been taken apart since it left the factory)
  • Worn out heating elements or timer.
    • Unfortunately these can not be replaced because they contain welded connections
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
How can you tell if the problem is the worn out elements, timer, or the heat controls?
von
Antwort hinzufügen
Alejandro Martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 61
Insgesamt: 18,633
