Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1966 Fragen Alle anzeigen
Backlight is out
So I dropped my iphone the other day and it cracked the screen and I decided to fix it myself to see what it looked like inside and to save a few bucks. I got everything replaced (LCD and Digitizer) but the backlight wont turn on. I restored the phone, fiddled with the brightness and even took it apart again and tried to clean the parts that I messed with with alcohol. Anyone know what cable needs to be fiddled with to fix it.
---Note---
I tried to see what it would look like with my old LCD and the backlight is also out there.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Antworten
Hilfreichste Antwort
The LCD connects to the logic board directly, via a single cable - Cable #1. Most likely, the logic board was damaged by the drop as well, causing the issue you are experiencing.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
well i hope thats not the case but when i dropped it and truned it on, the LCD backlight was still there so I dont think its damaged. how should I clean the connectors, people say toothbrushes but thats not helpful enough -_-
von
After installing ifixit's Front Panel Kit (glass and digitizer only), my backlight initially wasn't working.
The second time I removed and reinstalled the screen, I noticed a piece of dirt in the female (case back) part of the #1 connector, preventing it from seating fully.
Once the debris was removed and the screen reattached, the backlight was immediately functional.
Bewertung 1
Antwort hinzufügen
Tommy wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 3,890
