Zum Hauptinhalt wechseln
Second iteration of Ematic's line of Genesis tablets. It was released in December 2012 and is powered by Android 4.0 Ice Cream Sandwich.
Why won't my tablet connect to WiFi?
Why will my Ematic Genesis 2 tablet not connect to the WiFi?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
hello, try to remove security from your network then log in (you should connect) and whether or not has any update available for your android ver. .Also, try changing the authentication method
von
Einen Kommentar hinzufügen
1 Antwort
Check to see if WiFi is turned on? And also if the router is connected and functional.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I try to turn WiFi on - it resists, then says, "turning wifi on" - never changes after that. Router is good.
von
Antwort hinzufügen
Brandon Key wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 860
