Zum Hauptinhalt wechseln
Reparaturanleitungen für das Magic Trackpad von Apple
26 Fragen Alle anzeigen
battery acid damaged batt-compartment - how to restore?
Hi together,
I own a Apple Magic Trackpad, where the batteries ran out and damaged the battery compartment.
I removed the batteries and cleaned the battery compartment. Now, the batteries have a little bit axial play (2mm?), so I have to put some metal spacer in between. And the Trackpad is only working sporadically, I suggest a bad contact problem.
When I look into the battery compartment, I only see a elastic radial spacer and a (always corroding) center contact.
Does someone has any suggestion, how to resurrect the trackpad? Is there any part missing in the battery compartment? A spring maybe?
Pic of contact
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Try using a Q-tip and some isopropyl alcohol (no contact cleaner) and or a toothbrush to scrub it away.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
kaufschorsch wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 174
