Zum Hauptinhalt wechseln
Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
Why isn't my tablet working
My tablet wont come on
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
What have you tried? Charged it? New charger;new cable?
von
Can you try to describe your problem in detail? What is the situation of your tablet now?
von
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
War diese Antwort hilfreich?
Bewertung 1
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
Bewertung 1
The Reason Is Probably Because It Needs To Be Restarted.
Bewertung 0
Antwort hinzufügen
Tina Stone wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 269
