How do I to turn on Wi-Fi for Trio Stealth G4X?
How do you turn on the Wi-Fi for the tablet?
Ist dies eine gute Frage?
To turn on the Wi-Fi setting on your Trio Stealth-G4X, simply press the settings icon on the home page (the default image should resemble a gear). In the settings menu, the Wi-Fi setting should be on the upper left hand side. Click the switch to turn it from "off" to "on".
Occasionally, your tablet may have troubles connecting to Wi-Fi even if the setting is on. This may be due to a weak connection, no connection found, or router/modem issues. Make sure that you are in range of a strong Wi-Fi signal. Make sure that you are using the correct Wi-Fi password on private connections. If your Wi-Fi continues to stay disconnected, you may need to reset your router or modem.
For additional help along with answers to similar questions, refer to the Trio Stealth-G4X troubleshooting page.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 67
