Display is not working
Hello,
after I start my laptop the load-screen is shown for about 10 sec after this the screen turns black. I know the laptop is still working and Windows is loading but without any graphic.
When I connect the laptop with an external Display, it works and I see the desktop external. This means the graphic card works but the laptop-display stays black. When I push the function button with f6 the lightning button the screen appears for some seconds on the laptop-screen and again nothing. What could be the Problem?
Thanks in advance.
Regards
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
the screen resolution iss to hight connect it to an external monitor and change the laptop resolution to 1024 resolution and it will work ..thats it
von
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
3 Antworten
Gewählte Lösung
YET, sounds like a backlight issue. This could be related to the screen or the inverter. I would start with a new inverter. Relatively inexpensive and not very difficult to change. Thsi video will give you an idea of what you are looking at.
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
Thank you oldturkey03. I will change the inverter in a few days. After this I will come back. :D
von
I changed the inverter and the problem is still there. Now Im sure it should be the screen itself.
Thank You.
Punktzahl 0
I had same problem on my Aspire 8920g in 2013. Just want to share my solution.
oldturkey03 is right that the problem is with backlight.
I solved it in two steps. Starting with easiest.
First - replace inverter, in my case the problem was still there, but for some users it can be solution.
Second - replace LCD CCFL Backlight. This step is more difficult, but with patience and skilled hand it is less than 2 hour job. To change CCFL is cheaper than whole screen.
You can find them for under $20, just search eBay for "LCD CCFL Backlight Aspire 8920",
example eBay link
I did this repair in 2013 and still PC is working without problems.
Punktzahl 0
Antwort hinzufügen
YET wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 57
Insgesamt: 1,651
