Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1232 Fragen Alle anzeigen
Frage geschlossen
Update and restore loop ios 8.4.1
I have an iPhone 5c which was badly damaged and after replacing most of the parts i tried to boot it however it has the itunes and lightning cable logo, itunes recognises its there however when i press restore iphone and then restore and update it goes into a never ending loop. I have downloaded all the recommended programs and still not luck. Help.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Also forgot to mention i was in the process of doing an OTA update to 9.1 then it was interrupted and has been doing the boot loop since
von
Have you attempted to restore the iPhone in DFU mode?
von
Einen Kommentar hinzufügen
1 Antwort
It sounds like you're stuck in a boot loop. One way to TEMPORARILY get out of this is to hold down the "+" volume button on your iPhone as soon as you see the apple logo appear. Keep holding the volume button! it will take longer than you would think! If this works, then plug it into you computer and restore it.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 215
