Engine starts, won't go forward or reverse.
I have a Toro Wheel Horse riding mower - engine starts, mower deck will engage, but it will not go forward or reverse. It will roll, however. What is the fix? Thanks.
Ist dies eine gute Frage?
Start by checking the cable from the handle bar to the drive it needs to be snug up enough to engage the drive when you pull it if thats ok check the drive to see if it is not a shear pin that may need replacing if it is not a shear pin then there is a slip cluch and this may need to be tightened Hope this helps
War diese Antwort hilfreich?
mines a 8-25 Toro wheel horse it has a problem with going up small hills in the yard like if i stop right on a hill then go it won't drive back up the hill I let it roll back then back up to get speed to make it up the hill or it will not make it up their
just putting it in 4 or 5 it takes a few seconds to go forward then it goes fast once it kicks in.
I have the Toro time cutter ss4225 doing the same thing it's not going forward or reverse it is a zero turn and the belt is on does that have more than one belt if not the belt is on and doesn't seem to have any problem but it will not go for a little reverse what could that be blades engage also
Chuck Severson, it will sure help if you can tell us what model your Wheel Horse is. Reason for that is the importance of how your drive is set up. If yours would be 260-series than you want to check things like this:
Symptom: Unit Does Not Drive
Possible Cause
Keys sheared in drive pulleys
Remedy
Replace
Possible Cause
Shift keys broken
Remedy
Replace keys, check keyways and shift gears.
Broken input gear
Replace
Possible Cause
Differential bevel gears broken
Remedy
Replace
Possible Cause
Stripped teeth on gears
Remedy
Replace
The very first thing that you do want to check is the drive belt of course. Again, part of this will depend on your mower model. something of a beast like a 603 is different than the hydrostatic drive of a 460....
I have a wheel horse model 281707.It will not shift out of neutral.Starts up and blades tuen on but will not engage the transmission. Any solutions?
There's a latch on the back of my Toro Wheelhorse that you disengage when you want to roll the tractor (for example, roll it into the garage, because you've emptied the gas for the season.) It needs to be moved over in order to engage the engine again. I learned that the hard way.
My Lt 1000 craftsman would barley move auto transmission. Fluid check looked like milk. Everything I read said no oil change possible. Oil should last a lifetime of transmission. Hydro Trans get very hot causing condensation. Was told must pull out Trans to change fluid. Right under the hydraulic release lever there is a flat spot on the case you can drill and tap a 1/2 inch hole for a drain plug. Then remove the fill plug on top of unit toward back of ring gear area . Remove battery box to locate refill with 20/50 oil 87 2.7 qts. I recommend synthetic. Jack up rear of tractor to fill . Purging air out is the hardest part with the right wheel off the ground you can start mower and purge air by putting weight on the seat put in gear and let run until the wheel start to turn when the whining noise stops air should be out of system. Drive it forward and backwords a few times and it should work better than ever before.
Toro 15-44 will not go into gear forward or reverse when I push the pedal also the thing you pull in the back to be able to push it does not engage or disengage as well so it's stuck where it's at it was fine when I parked it now it does nothing what do you think could be the problem
I just bought a old new Toro wheel horse 8-25 and it works and cuts the grass it drives fine on flat ground I drove down a hill then went to ride back up the hill and it would not ride back up the hill so i had to back up and get speed then it went up the hill but slows down a bit going up it's got to have something to do with the oil or gears
It doesn't take right off neither when I put it in drive
My other backup driving mowers do they don't do what this Toro wheel horse 8-25 does on going up hills. It's like a gear isn't kicking in just to drive up a small hill the engine is a Briggs and Stratton 16-Hp.
did you shift in in reverse while going forward or shift up a gear while moving if so you probably broke the shift keys
I have a Toro riding mower model # 71227 while mowing the mower stopped moving forward or reverse. Mower still runs and mower engages
My Toro 50 50 won't go forward or reverse but will turns left and reverses to the right. Will go in circles. Replaced the brake box and belts are good. Any
suggestions?
Sounds like your bevel gears in your differential are worn out.
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 51
Insgesamt: 79,189
1 Kommentar
I have a Toro 32-10B501 toro wheelhorse I used it today and went down a hill then it would not go forwards or backwards what do I check 1st the gear did move the cable underneath so I don't think that is an issue
von Steven
