Zum Hauptinhalt wechseln
doesnt read g-rom any more.
The DC turns on and the menu works fine, (can set time play CD's np) but when i try to play a game (any game) it just goes black like it is gonna start but just goes back to the menu someone plz help I want to play my DC again!
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
There is a fix for this. It involves a small screw used to adjust the power of the laser. This link gives a step-by-step guide. I used this to fix the same problem on my dreamcast.
http://www.ilovetheinternets.com/2004/04...
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Webers think alike! I've fixed 5 DCs this way. Easy to do!
von
Hey Does it just reboot. if so you have to take it apart and clean the power pins that connect the power supply to the motherboard with alcohol you may also have to bend the pins a little bit to make them connect with the pins on the power supply better as well. that worked for me.
Bewertung 0
Antwort hinzufügen
Greg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 2,477
